heater not blowing very warm
Old Dec 20, 2006 | 02:23 PM
daveranger's Avatar
Default heater not blowing very warm
Hello, I have a 92' Ford Ranger with 2.9 V6. My heater is not blowing warm enough. It is not cool, but mildly warm. Radiator, hoses, coolant, water pump,coolant temp sender, fan clutch are all ok.
Could there be a slow leak in the heater core? Last time this happened, steam came out the vents. But there was no spillage inside the truck.
Old Dec 20, 2006 | 09:08 PM
rtmtrrdr's Avatar
Default RE: heater not blowing very warm
did you replace the heater core?
Old Dec 21, 2006 | 12:44 AM
wheelsup68's Avatar
2 things come to mind really quick. You did not mention thermostat being new, and how about the heater controls? Can you verify that the heater door is closing all the way when the temp is on full hot?
Old Dec 23, 2006 | 04:48 PM
daveranger's Avatar
Default In answer to your questions to my inquiry "heater not blowing very warm"
I actually did replace the heater core. The heater control seems to be ok. How can I verify if heater door is working ok? The thermostat was replaced last year at the same time I replaced the radiator.
Thanks,
Dave
Old Dec 24, 2006 | 12:40 AM
wheelsup68's Avatar
Default RE: In answer to your questions to my inquiry "heater not blowing very warm"
Is there any way that you can reach the blend door actuator? If so see if you can manually close this door any further than the controls will allow them to function.
Old Dec 24, 2006 | 01:01 PM
daveranger's Avatar
Default answer to wheelsup
Hi wheelsup, I don't know where the blend door actuator is. I assume somewhere under the dashboard?
Last few days it has been blowing nice and warm. Could be one of those intermittent problems.
vanpraag
Apr 6, 2013 02:28 PM
willtransco
Feb 11, 2010 06:32 AM
sk8terswife
Jan 5, 2009 12:50 PM
ratley
Dec 1, 2008 04:41 PM
MGood777
Sep 27, 2008 07:57 PM
