i have a ? please need help
Old Mar 21, 2007 | 10:52 PM
corisco's Avatar
Default i have a ? please need help
ifi unplug the resinator from the air box will the check engin light go on let me know
and if the check engin light does go on when i plub back the resinator will it shut off
Old Mar 22, 2007 | 02:07 AM
goinstrong's Avatar
Default RE: i have a ? please need help
Resonator I know does nothing but even out airflow (not important).
Old Mar 22, 2007 | 05:19 PM
corisco's Avatar
so will the check engine light go on
Old Mar 22, 2007 | 11:18 PM
goinstrong's Avatar
I doubt it. Unless it has wiring connected or sensors it's a secondary deal.
Old Mar 22, 2007 | 11:19 PM
goinstrong's Avatar
Does the air filter box have a wired in sensor?
Old Mar 23, 2007 | 05:57 PM
corisco's Avatar
i dont know how do i find that
Old Mar 23, 2007 | 06:04 PM
What year and engine?
Old Mar 23, 2007 | 06:43 PM
corisco's Avatar
2007 4.0
Old Mar 23, 2007 | 09:43 PM
The Mas Air Flow (MAF) sensor and the Intake Air Temp (IAT) are incorporated into the same sensor mounted into the intake stream.. If you unplug this sensor and run/attempt to run the engine, the CEL will illuminate and set a DTC.. The code and light can be cleared by just disconnecting the battery.. Although if a diagnostic scan isneeded ordone, it won't 'complete' the diagnostic test until normal driving strategies are met and diagnostic monitors have reset.. In short, it would need to be driven for some extended miles to read or check for trouble codes..
Here's a few pics of the sensor/location
[IMG]local://upfiles/6756/6B41956915BF4601B3707DCAF18AC854.gif[/IMG]
[IMG]local://upfiles/6756/E80876EF37914A27A388AE019F2B0ED3.gif[/IMG]
Old Mar 24, 2007 | 12:39 AM
goinstrong's Avatar
I was expecting an older deal. I regret new cars more and more each year. Too much crap - plain and simple.
trapperdon
Nov 8, 2014 05:52 PM
151stRanger
Jan 9, 2010 04:16 PM
turtlefrogs
Jan 3, 2009 09:55 PM
davequest
Sep 12, 2006 04:16 AM
