problems with my 96' explorer
Old Feb 16, 2007 | 06:56 AM
KNahinu's Avatar
Default problems with my 96' explorer
Hi I have a 96' explorer with auto trans.,and a 4.0 engine.
The problems I'm having is :
1) reverse lights don't work.(changed neutral safety switch)
2) O/D light flashing
a) hard shifting up and down shifting
b) sometime sticking in second gear
When O/D light is not flashing trans shifting is fine..
3) Power windows controls work only from drives's seatonly.
Old Feb 16, 2007 | 01:02 PM
Default RE: problems with my 96' explorer
If you've replaced the TR (trans range sensor) and was aligned correctly, you must have a problem in the circuit/connector or power distribution.. Check fuse position #26/10amp.. There isn't much in the circuit to power the backups, and all of the symtoms you describe as far as harsh/firm shifts engagements or even wrong gear can occur for a bad or out of range TR sensor.. Or if power to the TR has failed..
Heres a few pics of the circuit and the power distribution...
[IMG]local://upfiles/6756/CA65BD64458E42DD80F635FDCCBAAA68.gif[/IMG]
[IMG]local://upfiles/6756/2F8E8C106ECE4E5D874C5019533547D3.gif[/IMG]
Old Feb 16, 2007 | 03:03 PM
KNahinu's Avatar
Thanks I changed the TR sensor and aligned with the special tool, when I changed the sensor the reverse lights worked now they don't.
babypumpkinhead
Nov 23, 2006 02:04 AM
975.030267ex
Feb 2, 2006 11:14 PM
jfh123
Dec 15, 2005 02:20 AM
nofearrider22
Nov 2, 2005 01:17 PM
justclickn4
Jun 20, 2005 07:39 PM
