RE: 1991 Ford Explorer Fuel Pump
Old Nov 6, 2005 | 12:35 PM
retread's Avatar
Default RE: 1991 Ford Explorer Fuel Pump
Receiving a "95" code when running a KOEO test. Motor will not start. Replaced fuel pump relay, no joy. Pump does not run when key turned on. Thinking fuel pump. Any other checks that can be run prior to purchasing and replacing fuel pump. Current pump was replaced approx. 5 years ago.
Old Nov 10, 2005 | 01:08 PM
retread's Avatar
Default RE: 191 Ford Explorer Fuel Pump
Since there has be zero replies to tthis post I thought I would write an update. Chilton's manual says to read voltage on the harness to the fuel pump. The reading was 6.8 volts. The manual goes on to say the reading should be within 0.5 volts of battey voltage. Replace the pcm relay if voltage differs as stated. I understand that, but I attached a test lead from battery directly to the fuel pump with a good ground. Fuel pump did not run. Should the fuel pump run when receiving power directly from the battery? Any help all will be appreciated.
Old Nov 10, 2005 | 02:33 PM
techmanbd's Avatar
I am not familiar with fuel pumps, but electrical I am. So is there only 2 wires? if so, then yes it should work.
Old Nov 11, 2005 | 01:17 AM
hockeyhitman69's Avatar
yes if you jumped it with battery voltage it should pump if it doesnt then probably our pump
Old Nov 11, 2005 | 01:19 AM
your pump..and check makesure you have a good ground
Old Nov 13, 2005 | 04:49 PM
retread's Avatar
Replacing the fuel pump. Have not seen the fuel line connectors before. How are they unlatched/disengaged? Special tool from ford or other methods?
Old Nov 13, 2005 | 05:54 PM
frdtek05's Avatar
The connectors are what Ford calls "Quick Connect". While it is a special tool in a loose sense, it should be available at any auto parts store for less than 5 bucks. It's slides over the metal part of the tube on the pump, a round flange releases the connector when it's pushed into the cylinder of the fuel tube. Theres a rubber oring in the fuel line side of the connector so I suggest smearing some vaseline on both sides of the connector once you're ready to reconnect them. On fuel lines as old as that, you could damage the oring and have it not seal correctly.
Old Nov 14, 2005 | 12:41 PM
retread's Avatar
Thanks for the response. Will try that this morning and post back the results. Thanks agian.
Old Nov 16, 2005 | 12:36 PM
retread's Avatar
Thanks for the response. The connectors came off. Found a loose hot lead wire to the pump. Replaced pump anyway. Also replaced the ECC relay. Motor started easily. Two questions: (1) Measured the voltage at the chasis harness to the fuel pump. Voltage = 6.8 volts. Used 2 meters to verify. The spec. is within 0.5 volts of battery voltage. Battery = 12.5 volts. Where does one go from here? (2) Next to the ECC relay and the Fuel Pump relay is a third relay. What is this one for?? I have researched Alldata and the Chilton's manual but have not been able to identify the relay. Thanks again for any and all responses.
jozepy24
Jul 13, 2019 05:21 AM
fordexpedition2006
Apr 21, 2017 05:23 PM
Spaznaut
May 24, 2014 02:10 PM
TAZ454
Dec 10, 2008 08:30 AM
Ford Man
Apr 5, 2005 03:57 PM
