04 f150 4.2l noise
Old Apr 8, 2022 | 03:22 PM
ndnluvr75's Avatar
Default 04 f150 4.2l noise
Popping at idle on 04 ford f150 4.2l with 209432 on odometer but had rebuilt engine put in 1 year ago so only 15000 miles on it. Approximately 2 months ago it started hesitating and stalling upon acceleration then a knocking sound, so I parked it and now it does it while idle and it's rough and occasionally hard start, when you Rev it up the popping somewhat subsides. Plugs are coming out with black soot so I know there is carbon build up. Checked numerous things and replaced coil pack, plugs/wires, knock sensor, IAMC, cleaned EGR, new gaskets on valve and manifold, everything is torqued to correct setting, new air filter and oil was just changed using same filter and oil as always.The popping sound is coming from where manifold and catalytic converter connect. Catalytic converter had busted honeycomb. Started once without knocking/popping and realized didn't have a plug in cylinder 1 so installed and started popping again?? Did compression test and all good, started it and it ran for about 1 ½ minutes then popping again. At a complete loss. I've searched and searched but find different answers and solutions. Can it be a vacuum leak? Timing? Injector? I'VE READ SO MUCH ABOUT THIS AND WATCED VIDEOS AND READ COMMENTS SO PLEASE SPARE ME THE SMART *** COMMENTS AND THE SAME STUFF I ALREADY MENTIONED ABOVE…. SORRY JUST AGGRAVATED AND REALLY NEED MY TRUCK. IVE ONLY DRIVEN IT 6 MONTHS FROM HOME TO WORK ABOUT 32 MILES EACH DAY. THANKS FOR YOUR CONSIDERATION….
ndnluvr75
Apr 8, 2022 02:25 PM
mikebruce700000
Feb 14, 2017 03:42 PM
Ryan ML
Mar 30, 2014 02:36 PM
trakker
Oct 10, 2011 06:12 PM
Stoneroses6300
Oct 6, 2007 02:48 PM
