09 f150 5.4 not starting
Old May 9, 2020 | 03:28 PM
Kodak's Avatar
Default 09 f150 5.4 not starting
My 09 Ford f150 5.4 will not start new plugs new battery just keeps on cranking like it's out of gas.
any suggestions?
Thanks
Old May 9, 2020 | 05:47 PM
Do you know how to check for fuel and spark?
Can you pull one of the spark plugs and let us know if it is wet or dry?
If it is wet, you are getting fuel, if it is dry no fuel. Does the check engine light go out while you are cranking the engine over attempting to start it?
Also , do you hear the fuel pump in the tank run for the usual 2 seconds when you first turn the key on?
Also, if you have a second working key, try the other key.
Old May 10, 2020 | 02:19 PM
Kodak's Avatar
Thanks Hanky
I found the fuel pump fuse blown. Imagine that !
thanks for your help
Old May 10, 2020 | 02:33 PM
If you decide to return to this thread, give the next thought some consideration.
Fuses usually don't open just for the heck of it, there is something going on that caused that fuse to blow.
If it doesn't happen again, great, If it does , we'll expect to hear from you. Happy motoring !
Old May 10, 2020 | 04:14 PM
Kodak's Avatar
That thought has been in the back of my mind.
fingers crossed.
Old May 10, 2020 | 05:30 PM
How many miles on the odometer?
Do you remember one of the things you could try if the fuel pump won't start, like banging on the bottom of the tank when the key is in the start position?
Does your truck have dual tanks?
EasyEf250
Aug 11, 2019 03:52 AM
Cody McCoy
Apr 6, 2019 11:36 AM
Adian226
Mar 17, 2019 05:42 PM
edvandermark
Jan 19, 2009 07:19 AM
AGGIEARCH2007
May 4, 2006 06:11 PM
