09 f150 air conditioer
Old Aug 12, 2014 | 03:58 PM
jmehan's Avatar
Default 09 f150 air conditioer
The system has freon but the compressor stops and starts every few seconds How do I fix it so the low pressure swich does not cut out?
Old Aug 13, 2014 | 06:24 AM
"Has freon", but is it a full charge? What are your LOW and HIGH pressure readings? Ambient outside air temperature for the gause readings? The cycling could be from a low charge, LOW pressure switch, HIGH pressure switch or even something else such as poor air flow causing high pressures.
Old Aug 13, 2014 | 02:08 PM
markmc60's Avatar
good answer, A/C probs like this can not be fixed or diagnosed without good gauge readings, nuff said.
tcaswell0282
Jan 16, 2009 10:40 PM
sgarcille
May 1, 2007 04:02 AM
