1978 f150 ignition no spark problem
Old Nov 22, 2010 | 07:54 PM
BonesMachine's Avatar
Default 1978 f150 ignition no spark problem
460 engine.
I have no spark. i just tried replacing the ignition coil to no avail. i installed an inline spark tester between the coil to dist wire and the distributor and no spark. I haven't tested resistance yet but maybe the wire from the coil and distributor is bad. the tester was plugged into this wire. I have 12 volts at the coil leads with the ignition turned on. I was wondering what other problems can happen before the coil even if the leads of the brand new coil are getting 12 volts from the control module. ballast resistor or other module problem? thanks....
Old Nov 22, 2010 | 08:44 PM
ok so i tested the coil to dist wire and it's ok. i also connected the spark light tester between the coil and directly to ground and nothing. just confused here since it's a brand new coil and it's getting 12 volts.?
Old Nov 24, 2010 | 12:41 PM
2 biggest problems were usually the module itself (can be tested) or the pick up coil in the distributor.
Old Nov 24, 2010 | 06:10 PM
way2old's Avatar
Does the negative side of the coil flash while cranking the engine?
Old Nov 28, 2012 | 03:11 PM
Badandy33's Avatar
I'm having the same issue and the negative side does not flash. It is steady on. What does this mean? I replaced the module after reading this thread. Still no spark
hubbard85
Jul 3, 2018 09:31 PM
mikep43019
Aug 11, 2014 10:48 AM
renegaderob18
Jan 5, 2014 03:17 PM
imprtslyer
Apr 28, 2011 09:49 PM
slingshot37091
May 1, 2007 03:55 AM
