1990 F-150 XLT Lariat. Wont start
Old Jun 6, 2017 | 06:45 AM
Dalton_eli_whisnant's Avatar
Default 1990 F-150 XLT Lariat. Wont start
I was having problems with my 90 f150. One of the tail lights would stay on like I was hitting the brake but the other one would not cone on at all. Except for the blinkers both blinkers works. Very weird. I replaced the bulbs and the sensor that's on the brake pedal and that fixed that then the next day I cranked the truck up and as soon as I got out of my driveway it shut off. I did a little research and determined it was the ECM (engine control module). I replaced that and the truck cranked up and ran good but shut back off after a couple minutes. I cranked it and it shut off 3 times. I then removed the brake sensor I had previously replaced and tried to crank the truck. It cranked up and idled well for about 10-15 min. I put the brake sensor back on and I drove it maybe 200 yards back to my house and shut it off thinking all was well and everything was fixed. The next morning I cranked it up to go to work and it idled for a min or two and shut off. Now it won't crank at all no matter what I do. If anyone has ideas please let me know I need help this is my daily driver. Thanks.
Old Jun 6, 2017 | 09:18 AM
Thumbs up
Welcome to the site..
Have or can you verify the fuel pump run, and a hot/active spark?
When the key is cycled to ON, pump run should be 'heard' for a few seconds as the system pressurizes. (PCM is in control of fuel pump relays grounding= run and times) Even if present, not a bad idea to verify fuel pressure and volume..
The intermittent run I'd doubt is related to brake lamp function, short etc.
Would be fairly common for a pump fail, pump relay etc to be or cause an intermittent and should be proved out. Same with an ignition/spark drop out.. Checking the two systems are functional would be my first step, and if both are present, checking for an injector pulse provided by the PCM..
cklamer
Sep 20, 2016 09:42 PM
cklamer
Jul 11, 2016 10:29 AM
Cody_Trots
Jul 21, 2013 02:14 AM
bigblock54
Sep 3, 2009 07:59 AM
91one50
Dec 17, 2008 09:12 PM
