1992 4.9 i6
Old Mar 21, 2022 | 05:27 PM
  #11
Removing the injectors just for checking is not recommended. Why?
The "O" rings on each injector will be damaged on removal and unless you replace the "O" rings with new,,,,,,,,,,you just created another problem
There is no sense to attempt to come to a reasonable conclusion if getting into areas when it is not necessary just creates another problem.
Old Mar 21, 2022 | 11:20 PM
  #12
jesus.14jesus@icloud.com's Avatar
Update. replaced all vacuum lines map sensor egr valve. Regard me listing to the injectors spraying it was only 2 out of the 6 so replaced them it turned on for a couple of seconds but bogged down and shut off so far going in the right direction getting closer to victory fuel pressure is still at 55psi
jwright0814
Jan 28, 2017 08:56 PM
thekid_jesse
Oct 19, 2015 07:36 PM
kalenkerby
Mar 27, 2014 03:58 PM
riekejake
Aug 24, 2008 09:54 PM
jeffreysroeth
Sep 23, 2007 10:11 AM
