1993 ford f150 camber question
Old Sep 23, 2013 | 02:02 PM
luigi87's Avatar
Default 1993 ford f150 camber question
hi I have a 1993 ford f50 4x4. if I put 33/12.5/15 tires on it can it cause my camber to be positive?
Old Sep 24, 2013 | 07:53 PM
luigi87's Avatar
any help would be nice
Old Sep 27, 2013 | 10:05 PM
luigi87's Avatar
does anyone know???????
Old Sep 29, 2013 | 11:41 PM
luigi87's Avatar
can anyone help me out I really want to know
Old Sep 30, 2013 | 08:08 PM
Shouldn't..
Since camber adjustment/s set the spindle/hub horizontal angle, without any higher lift springs/kits etc. or any geometry changes to the front hardware, tire sizing should only affect chassis/cab height, but shouldn't change camber.. The 4x4 axle runs very little if at all camber. Stock rims? Camber/caster is adjusted with the upper joint offset bushing. If the upper joint has any wear, and it hasn't been aligned for a while, chances are the camber maybe - or flat to start..
Old Oct 1, 2013 | 11:51 AM
luigi87's Avatar
I will be using stock rims
rcoelho
Feb 13, 2022 07:52 AM
CW
May 3, 2008 08:19 PM
sbcadillac
Apr 11, 2008 11:49 AM
spinbad
Dec 22, 2006 12:27 AM
Kjack
Mar 7, 2006 03:14 PM
