1994 F150 loss of power
Old Feb 4, 2024 | 04:00 AM
paulwhitey's Avatar
Default 1994 F150 loss of power
Starts ok, ticks over fine till it gets warm or travels a mile and then it loses power. Can,t cope with any gradient in road. Bangs and pops, Sounds like misfire.
I have replaced fuel injectors, fuel filter, fuel pump, fuel tank, egr valve, pressure regulator on fuel line, throttle position sensor, oxygen sensor, vacuum cannister, coil, ht leads, plugs, distributor cap.
Could not change the map sensor because i have LPG conversion.
I have an oxygen for the exhaust but haven,t replaced yet.
Have no catalytic convertor was removed 10 years ago and has been running fine until now.
While running for an hour perfectly fine did timing and its spot on.
Any one got any ideas. I,m at my witts end.
Cheers
It is a Ford F150 1994 5 litre V8 efi (fuel injected) No Carb
Last edited by paulwhitey; Feb 4, 2024 at 04:09 AM. Reason: not enough detail about model
Old Feb 4, 2024 | 08:22 AM
You might want to keep in mind the fuel pump is electrically controlled and you could be missing the cause.
The ECM, controls the fuel system so there is plenty of things to check out.
What i suggest is to connect a fuel pressure gauge and set the gauge where you can see it and when the vehicle begins to falter ,see what the gauge is showing.
Can you do this?
94Fitty
Jan 27, 2020 01:11 PM
colorado
Jun 6, 2017 09:43 AM
Flapless Jack
Dec 3, 2012 06:28 AM
jubylives
Sep 28, 2010 02:51 PM
OldMansF150
Jun 17, 2010 03:53 AM
