1997 ford f150
Old May 14, 2020 | 04:07 PM
JASON82's Avatar
Default 1997 ford f150
Ok people I have a 1997 ford f150 xlt 4x4. It as the 4.6. I got in it the other day the starter dragged when starting and just quit. Turn the key and nothing. The truck fires up at the firewall solenoid.
I tried to drive it but the pcm but the truck in limp mode. I have replaced the firewall solenoid,starter and the neutral safety switch. Same result turn key and nothing. Check engine light is on and gives codes a flows. Torque converter clutch circuit electrical, transmission range sensor circuit high,shift solenoid a and b. Does ANY BODY have any advice?
Old May 15, 2020 | 03:26 PM
raski's Avatar
The PCM will not keep the starter from cranking. Did you jump across the solenoid or did you apply 12v to the small connector to energize the solenoid? I suspect a wiring issue between the ignition switch and the solenoid or the ignition switch itself. I would address the cranking issue first then the stored codes.It is very rare to have a problem with the neutral start switch but the wiring is possible.
Cody Long Sr.
Feb 20, 2020 10:12 AM
Dayday76
Apr 21, 2019 07:20 AM
Blackfoot1954
Aug 19, 2018 04:07 PM
iuecbrad
Mar 16, 2012 11:58 AM
iuecbrad
Dec 22, 2011 08:10 PM
