1997 Ford f150 whistling
Old Apr 21, 2019 | 03:20 PM
Dayday76's Avatar
Default 1997 Ford f150 whistling
97 Ford f150 makes whistling sound when I press the brake pedal. That's the only time I hear the noise. Also noise is only heard in the cabin not on the outside. Any advice?
Old May 2, 2019 | 05:40 AM
raski's Avatar
I had that happen and it was the brake booster with a leaky diaphram. You can check by pumping the brakes after around 15 minutes after shutting down the engine. You should get 3-5 power assisted pumps before the pedal gets hard. If not, check the one way vacuum check valve which is plugged into the booster. If it is ok, you likely have a bad booster which is behind the master cylinder.
rdana
Jul 21, 2019 05:31 AM
Dayday76
Apr 21, 2019 07:20 AM
cesarhernandez74
Jul 29, 2014 02:05 PM
fordtruck1
Jun 21, 2010 09:19 AM
jonas74
Aug 7, 2005 11:25 PM
