1998 F-150 Wont Start
Old Jun 22, 2007 | 09:31 AM
nancylynn's Avatar
Default 1998 F-150 Wont Start
I have a 1998 Ford F-150 with a little over 200,000 miles on it, I drove it last night and it was fine, got up today and it wouldn't start, it just clicks, I have replaced the starter and the battery, it still just clicks any sugestions on what else to try, I am really desperate, this is my wheels to work, gotta work to eat.
Old Jun 22, 2007 | 09:33 AM
nancylynn's Avatar
Default RE: 1998 F-150 Wont Start
I also changed a selenoid on the fire wall
Old Jun 23, 2007 | 12:05 PM
runningwolfnaked's Avatar
same thing happens to mine its and automatic transmission, found if I try to pull the shifter hard into the park and hold it ,it helps to turn overand start also if that fails to work sometimes I can put it in neutral and it will start, make sure you apply brakes if you do neutral. seems to be faulty park switch or adjustment.
Old Jun 23, 2007 | 12:07 PM
oh yea if neither of those work try jumping screwdriver across solenoid to hot cable with ignition on.
Old Jul 25, 2007 | 09:02 PM
justinmayo2006's Avatar
try replacing the altenator! mine is doing the same thing when i charge the battery up it will crank an run fine for a while! i put a brand new batter an had the altenator checked an it is good! so i dont know what else to do ne ideas!?
Old Jul 26, 2007 | 05:52 AM
FordNutz's Avatar
Clean those terminals and clean those ground wires. I've added more grounds to help keep this from happening. A bad ground (dirty/corroded) can cause this.
Old Jul 26, 2007 | 11:24 AM
Bullitt94's Avatar
Definetly clean the battery terminals and wires before spending more money...
mharmonus
Feb 18, 2008 08:18 PM
cgl
Dec 9, 2006 07:36 PM
cgl
Dec 8, 2006 07:38 PM
truefordman73
Oct 28, 2005 06:50 PM
truefordman73
Sep 20, 2005 01:11 AM
