1998F150 power windows etc. won't work??
Old Feb 1, 2016 | 04:09 PM
Realdealbeal's Avatar
Default 1998F150 power windows etc. won't work??
Hey guys
My 1998 F150 has 248,000 miles on it. Recently the power windows, windshield wipers, door chime, and courtesy light all quit working. I have looked at the fuses in the passenger compartment and the power distribution box and they seem to be ok. Which ones am I looking for and what else could it be?? It would make me think they are all somehow connected, or at least I hope so!
Thanks for the feedback.
Old Feb 2, 2016 | 12:59 PM
Shay_Fox's Avatar
Welcome dear on a forum. Check the ignition switch connector at the base of the steering column. Chances are it's burnt and distorted. If so, replace the switch and the connector. By switch, I mean the electrical portion at the base of the column, not the cylinder at the top.
Old Feb 2, 2016 | 11:49 PM
Originally Posted by Realdealbeal
Hey guys
Welcome to the site..
The GEM/CTM (generic electronic module/ central timer module) has all the listed devices/features in common and are GEM controlled functions. It should have the GEM checked for codes to see if any DTC's are stored, or a possible direction..
Old Feb 3, 2016 | 07:49 AM
Through a little research, I thought this may be the problem. How do I check to see if they're are codes for the GEM? If they're were codes, would I just need to replace the GEM itself?
Old Feb 3, 2016 | 12:08 PM
Alanah_Rae's Avatar
Yes you have to replace the GEM..!!
Old Feb 3, 2016 | 12:59 PM
It will need to go to someone that has diagnostic scan capability to check for GEM codes. Getting the code definitions if any would be the first step for direction. Quite a few variables or possibilities involving the GEM. Given there history, a possible cause, but you don't want to replace good parts...
Old Feb 3, 2016 | 02:39 PM
LakelandFordParts's Avatar
Former Sponsor
If you do end up needing a GEM module let me know and I can check the availability and price for you. There are A LOT of GEM modules on backorder right now.
Old Feb 5, 2016 | 02:29 PM
So I pulled GEM Module today. Do I have to get one with the exact same serial number? I thought I saw a separate post where you could get a newer one, just not an older one.
My serial number is:
F75B-14B205-MB
If so, how do I know which ones are compatible?
Thanks
Old Feb 8, 2016 | 11:03 AM
Former Sponsor
F75B-14B205-MB
Thanks
I just received/responded to your PM. Part number F75B-14B205-MB is an engineering number for service part number F75Z-14B205-MA. That part supersedes to the newest remanufacture number EL3Z-14B205-BRM (EL3Z14B205BRM | FL Body Control Module) and unfortunately that part number is on a nationwide backorder with no ETA due to a core shortage. From my experience parts like this are typically on backorder for an extended period of time. I apologize about the inconvenience that I am sure this causes.
BlackandBlueBully
Aug 6, 2012 08:02 PM
db508
Aug 23, 2010 12:35 PM
gdt928
May 29, 2010 03:20 PM
Alex
Dec 4, 2007 06:40 PM
dale54
Mar 22, 2007 02:17 AM
