1999 F-150 wont shift
Old Mar 24, 2013 | 08:15 PM
BAleroS's Avatar
Default 1999 F-150 wont shift
Did I little searching on here, but couldn't find the answer I wanted. So here's the scoop. Title says 99 but it's a 97
My 97' F-150 does not like to shift out of park, after checking some things, the brake lights work at various levels of peddle pressure, and as most of you know, if the brake lamps are not on, the vehicle will not shift. This started about a week ago and I don't have any problems driving it, but sometimes it takes a while to find a pressure on the brake peddle that works to shift.
So I am just wondering is there a fix for this, and what is the issue? Fuses are good. Is there a sensor for the brake that's not getting a good connection or voltage?
Old Mar 25, 2013 | 01:13 PM
way2old's Avatar
Either adjust or replace the switch.
Old Mar 25, 2013 | 02:05 PM
BAleroS's Avatar
What switch is it? Break Pressure Switch?
Old Mar 26, 2013 | 04:47 PM
way2old's Avatar
It is more than likely the brake light switch on the steering column where the brake pedal bracket almost touches the steering column.
BAleroS
Mar 25, 2013 09:31 AM
gregorys81
Dec 13, 2012 01:54 PM
silverT1000
May 3, 2007 12:51 PM
93f250xlt4x4
Nov 5, 2006 05:42 PM
dilligaf58
Sep 12, 2006 07:57 PM
