2000 ford f150 5.4 2v running roughly
Old Sep 16, 2019 | 09:29 PM
Casey Charles's Avatar
Default 2000 ford f150 5.4 2v running roughly
Ok so im picking up a 2000 ford f150 5.4 and i went and checked it out and it runs and drives but not good i unplued each coil on the driver side and did notice it made it worse did the same on the passenger side and no change in performance
Old Sep 17, 2019 | 11:39 PM
UPDATE: checked compression on passenger side had 80 on each cyl and 125 on the driver side took front cover off and pass had jumped time about 3 teeth and the main Guide had came apart going to fix it and see how it runs will update more to varify that was the problem
Old Sep 19, 2019 | 06:33 PM
Re chain it and test the comp before buttoning up ..
EasyEf250
Aug 11, 2019 03:52 AM
Tuner77
May 24, 2018 08:10 PM
Vicky Lassetter Cagle
May 14, 2013 09:31 PM
strand02
Jul 26, 2010 09:57 PM
dmchurner
Jun 20, 2010 04:14 PM
