2004 F150 Rough Idle
Old Aug 24, 2010 | 07:52 PM
barkley44's Avatar
Default 2004 F150 Rough Idle
I have an 07 F150 with a 5.4, 133000 miles and it has a rough idle when first started. It seems to go away once I start driving.
Plugs and boots have been changed, no check engine lights. Also, milage seems to be down 1-2 mpg.
Any info is appreciated
Old Aug 25, 2010 | 08:41 AM
Bullitt94's Avatar
I always recommend running a can of fuel injector clean in a tank of gas as the first line of defense. It's cheap, and even if it doesn't work you certainly aren't hurting anything. My favorite is Sea Foam, but there are plenty others out there, too. Wouldn't hurt to change your fuel filter and air filter if it's been a while, too. If none of that helps, you may want to clean your IAC.
Sandman400
Mar 30, 2013 12:46 PM
04f150dude
Oct 21, 2010 06:15 PM
Olpapa
May 18, 2008 03:22 PM
ghogs5
Aug 13, 2007 01:34 PM
