2005 5.4 making noise at 1000-1050rpm
Old Mar 13, 2013 | 10:13 AM
Flybywire's Avatar
Default 2005 5.4 making noise at 1000-1050rpm
I have a 05 f150 with 5.4l 109,000k miles on it. When the rpms get around 1000 to 1050, I'm getting somewhat of a grinding maybe rubbing noise. It makes the noise at that rpm no matter what speed I'm going. Anybody else had this problem? The noise sounds like its coming under the drivers side wheel well.
Old Mar 15, 2013 | 10:21 PM
FordLifeSaver's Avatar
Just answer me this question. When you get oil changes done. Do you get aftermarket oil filters put on.
Old Mar 16, 2013 | 06:52 AM
Flybywire's Avatar
Yes I do.
Old Mar 16, 2013 | 07:22 AM
Unfortunately, there is a lot of aftermarket junk out there, imported, and is of lesser quality. We are paying the price for good quality and buying junk. If you get the opportunity check where your filters are made and that should answer a lot of your questions.
Old Mar 16, 2013 | 07:31 AM
Noises travel sometimes and something like a worn tensioner pulley bearing can produce a squealing noise. Timing chain tensioners are also in that noise group.
Sometimes in spite of your best efforts things wear and problems come around. Have you had anyone check for the source of the noise?
Old Mar 16, 2013 | 10:28 PM
Flybywire's Avatar
Thank you for the information, I have had it checked and they can't find anything wrong with it.
trev0006
Oct 16, 2010 03:14 PM
yesitsfree
May 6, 2007 03:45 PM
jasonb
Mar 27, 2007 10:17 PM
RJL88
Nov 4, 2006 01:41 PM
ranger83
Nov 6, 2005 01:23 AM
