2012 Ecoboost crank no start
Old Apr 9, 2023 | 05:49 PM
l1byan's Avatar
Default 2012 Ecoboost crank no start
crank no start with errors P0122 P0222
PCM yellow wire terminal 7 gives 5 v when harness disconnected. when connecting C1551E it's grounded.
tested yellow wire there's no short.
Old Apr 18, 2023 | 01:41 PM
dmckenzie's Avatar
What lead up to the no start? Those are throttle body codes saying the pcm detects low voltage on throttle body sensor A and B circuit. You could try erasing them and seeing if they return. Also if you have a scan tool that can read live data check out the PIDS for throttle body sensor and it should show open percentage and voltage. Slowly press the gas pedal while watching the PIDS and the open percentage should rise as you’re pressing on the gas pedal
Richard2012F250
May 29, 2022 04:05 AM
zorrow7
Nov 6, 2021 12:08 PM
Stacey Miller
Central
Jan 3, 2020 06:15 PM
Alberto Villacorta
Aug 11, 2017 02:57 PM
GCVB
Nov 11, 2012 09:22 PM
