2013 f150 crank no start.
Old Jul 22, 2024 | 01:37 PM
Bradbrown1997's Avatar
Default 2013 f150 crank no start.
2013 f150 5.0
Over a year ago, I had the fuse 27 go bad. Ordered the replacement, and it worked since then. Started the crank no start again and we replaced the fuel pump. Worked for a week then stranded me again. Dove into YouTube again and replaced the fuel relay module. Worked for a day then stranded me again. When I got it started, I took it to a shop and they kept it for 3 months. They replaced a crank sensor, fixed a ground cable, and found some ignition slop that was not telling it to give gas on the start up. Worked for 1 day and now I’m stranded again. What else could be wrong? Anyone have this ongoing problem?
Old Jul 22, 2024 | 01:45 PM
Every time somebody replaces a part , they move wires. Sounds like a bad connection in the wiring. You might consider a shop that has the equip and knowledge to chase this down. Appears they are guessing .
Old Jul 22, 2024 | 01:50 PM
it starts after it sits for an hour +. Would wiring cause that?
Old Jul 23, 2024 | 07:18 AM
I don't at this time know what the fuse you replaced protects.. ANYTIME, a fuse blows there is a reason, the current in the circuit became more than what the fuse is rated to carry. Since the fuse doesn't open ALL the time, the problem is intermittent.
What should be considered is to check for fuel and spark when it will not start. Can you do that? Depending on what you find there will determine what we do next..
Old Jul 23, 2024 | 02:41 PM
I don’t know how to test for that. I know when the fuel pump was replaced, it was not sending fuel before and then it was. I think there is spark since it cranks hard. It just won’t start up.
Old Jul 23, 2024 | 02:45 PM
This is what it is doing
File Type: mov
Kirk byrd
Jun 16, 2024 02:27 PM
Tonywerner
Sep 9, 2022 06:24 PM
brankuh
Apr 24, 2022 10:36 PM
ef2425lae
Jul 7, 2020 12:52 PM
Brennan Reece
Jun 13, 2017 09:12 AM
