4x4 shift fork?
Old Aug 12, 2025 | 12:21 PM
lesliexlt's Avatar
Default 4x4 shift fork?
Hello all. I have a 97 f150 4.6 4x4 that was n and out of 4 wheel drive for a few miles. I repaired the blue vac line that caused the issue. So I put the truck on jacks and put it n 4 lo. All 4 wheels spin, but the front spin faster(while n drive/idle) than the rear. Also I can stop the front by hand, and the pass front won’t start spin again like the driver side does. Is this normal or have I messed up the shift fork? Any thought would b a great help. There’s no grinding noise, but I was n the truck when this happened so not surepp
Old Aug 12, 2025 | 04:53 PM
I do not believe you messed up anything, what you described would be considered normal.
If you can , read up on just how a transfer case works AND a differential and you will see why there is no cause for worry at this time.
Old Aug 18, 2025 | 09:42 PM
lesliexlt's Avatar
Thanks for your reply. I have since removed the inner shaft and fork/slider. Fork and pads r like new. No wear on the gears or slider/washer. The fluid was grey but not gritty of metallic. The reason I pulled it apart is there is a bad rubbing sound coming from truck with wheels on the ground. I put truck on the lift and hear nothing. N 4lo, 4hi, and 2 hi. But wheels on the ground and a growl rub sound come from middle of truck rubbing increases with speed, sound continues on deceleration. I also found tranny fluid n transfer case about 2cups, which is what the tranny took last week when checked.
Ya
Old Aug 19, 2025 | 02:11 PM
Growling noise many times comes from bad bearings.
Noises do telegraph sometimes and can take you for a real ride trying to pin down.
A homemade stethoscope is very helpful for something like this, use a piece of hose , just be careful of moving parts.
2003Heritage4X4
Dec 17, 2013 02:31 PM
Manybeards
Jan 18, 2013 07:32 PM
kalabula
Sep 24, 2011 06:40 PM
F350welder
Dec 21, 2007 05:49 PM
alty79
Dec 12, 2005 11:19 AM
