4x4 won't engage
Old Dec 8, 2007 | 03:34 PM
jtm97ford's Avatar
Default 4x4 won't engage
hey guys,
is there a way to check the soleniod to see if they are working. i have a 97 4.6 the front tires will not engage. i have read alot of the questions and answers that have been giving. it seems i either have bad soleniod or vaccume leak. is that correct. any help would be great. thanks jamie
Old Dec 8, 2007 | 06:00 PM
BRETM's Avatar
Default RE: 4x4 won't engage
Easiest way is to disconnect the vacuum lines and inspect them, have seen ones where battery acid eats through the lines causing no 4x4 engagement. Then check vacuum coming out of solenoids when you engage of disengage 4WD.
George04
Dec 5, 2007 06:12 PM
benny1277
Dec 12, 2005 04:11 AM
cubsbz
Nov 12, 2005 06:39 PM
Dan71
Sep 6, 2005 12:11 PM
Dan71
