86 f-150 carb.
Old Oct 26, 2005 | 04:18 AM
truefordman73's Avatar
Default 86 f-150 carb.
i just have a quick questiong that has 2 parts to it. first will i see a change in gas milage if i change my carb from the fact. 4bbl holly to a 2bbl? what will happen if i shut down 2 of my jets on my carb????
Old Oct 26, 2005 | 01:22 PM
josser's Avatar
Default RE: 86 f-150 carb.
many part answer! the factory 4bbl was set for optimal fuel economy, yes if you change carbs you could change your gas milage, if you go with a 2bbl that has the same CFM's as the 4 bbl than you should may see improvement, on the other hand, if the 2bbl carb is smaller you will reduce the air intake and therefore rob your engine of power, meaning your engine will work harder and use more gas to do the same work as before.
If anything i would get a new 4bbl holly with same CFM's as the old one, new carbs are more fuel efficient and give better performance.
mich04
Jul 7, 2013 08:27 AM
cdale_sam
May 16, 2009 06:23 PM
hix007
Oct 13, 2008 02:50 PM
hix007
Oct 8, 2008 11:00 PM
hicracer
Jan 27, 2005 03:31 PM
