88, 302 revs high when shifting
Old Sep 10, 2005 | 06:06 PM
live4weekends's Avatar
Default 88, 302 revs high when shifting
Need help identifing where my problem may lie.
1988 F150 Custom, 302 V8 4X4 Manual tranny
Once the engine has warmed up I have an intermitant problem (more often than not) with the engine reving high when I change gears. When I engage the clutch the engine will rev upwards of 2500 rpm. for aprox 3-5 seconds then come back down to normal.
I changed the throttle cable a while back and it seemed to fix the problem for a couple of months but now the problem is back.
Has anyone had a similar problem ?? and if so what was the fix.
Any help would be apreciated.
Old Sep 11, 2005 | 12:08 AM
rusty ol ranger's Avatar
Default RE: 88, 302 revs high when shifting
Could be a IAC or sticking throttle cable.
Take some WD40 and lube everything good.
later,
Dustin
Old Sep 11, 2005 | 02:32 PM
Thanks for the sugestions.
Excuse my ignorance but what is IAC
Old Sep 11, 2005 | 03:59 PM
techmanbd's Avatar
WD 40 is fine, but when it comes to cable lines I would go with a good lubricating grease.
Old Sep 12, 2005 | 12:22 AM
IAC- Idle air control.
Controls the amount of air getting in at idle.....therfore controling idle speed.
later,
Dustin
bfuller9999
Oct 26, 2012 11:24 AM
blacktibby07
Sep 26, 2011 11:36 PM
charlespete
Nov 10, 2010 07:42 PM
hockey_head
May 13, 2008 10:19 AM
icedog
Jan 21, 2008 07:04 PM
