88 F150 continous crank
Old Sep 23, 2005 | 01:59 AM
KellyMiller's Avatar
Default 88 F150 continous crank
Hi everyone. I have an 88 F150 302 that I am having some major problems with. It started with just whenever I'd turn the key on it would continue to crank until the battery ran down, then I would wait a bit and it would fire right up. Now whenever the battery is hooked up it tries to start. We've replaced the alt, the battery, the starter solenoid, the starter, the ignition switch, and the ignition lock cylinder. Now I'm being told it's in the wiring. Any ideas on where to start??
Thanks in advance,
Kelly
Old Sep 23, 2005 | 05:02 PM
cctxfish's Avatar
Default RE: 88 F150 continous crank
Check to see if you got 12V at the (ithink) blue w/red wire at start soleniod.
http://www.autozone.com/servlet/UiBr...3d800c9f59.jsp
wasn't much help to me [:@]
Old Sep 24, 2005 | 11:59 PM
I finally called on a friend who knows a lot more then I do and he got 'er fixed! Yee-haw!! The postive wire from the starter solenoid to the battery was bad.
BTW - that webpage at Autozone.com didn't do me much good either.
Thanks for your input
Kelly
mudgunner1
Feb 12, 2015 05:59 AM
Bigpun
Mar 24, 2014 07:49 PM
agent008
May 11, 2010 06:14 AM
ladyferricher
May 6, 2004 01:44 PM
