89 F150 Cutting Out, starting problems
Old Jan 2, 2006 | 05:56 PM
arcduncan's Avatar
Default 89 F150 Cutting Out, starting problems
1st of all, thanks to everyone who posts here, it is a huge help.
My problem is in a 1989 ford F150, 2wd, reg cab, inline 6 cylinder, manual trans. I have only had the old truck a a month. While driving, the truck just cuts out. Every gear, at about 1/2 way down on the gas pedal, the truck just loses power. If you press the clutch and rev it up, it seems to be ok until you grab another gear and the truck gets back in the same rpm range. No service engine light is on. I replaced the wires and plugs and fuel filter. It has also had some starting problems and I think a new fuel pump relay fixed it? (also fixed 2 vaccum lines at the same time) Truck ran flawless for the first couple of weeks and then the starting problems started occuring and I let it sit for about 2 weeks before getting it started yesterday. Thanks again and any help would be greatly appreciated.
Anthony
dshaw11
Dec 21, 2006 02:08 PM
brotherxb03
Sep 14, 2006 01:00 AM
bluecarpenter
Jul 15, 2006 05:05 PM
leo_clarke
Jan 16, 2006 02:29 PM
markp
Mar 1, 2005 06:23 PM
