89F150 won't start
Old Jul 22, 2011 | 11:05 PM
rick32's Avatar
Default 89F150 won't start
Hello all my problem started Suddenly. One day I drove it all.was fine the next day it would die when I put it in gear. Now it won't even start. I've changed the fuel filter cleaned the valve which I believe is the IAC. Checked the fuel pump ,vaccum and still no luck any suggestions would be greatly appreciated.
Old Jul 23, 2011 | 07:43 PM
way2old's Avatar
Are you getting any spark? Sounds like it may be an ignition module failure.
Old Jul 28, 2011 | 12:21 AM
rick32's Avatar
My ignition module checked OK. Replaced coil cap and rotor. Still no luck.
Any ideas?
Old Jul 28, 2011 | 02:18 PM
Do you have a working test lite?
Old Jul 29, 2011 | 09:27 AM
rick32's Avatar
Yes I have one
Old Jul 29, 2011 | 01:39 PM
OK, with the test lite hooked to a good ground,
1. With the key turned on you should have 12 volts coming into the coil.
2. when cranking with the test lite on the other coil primary terminal you should get a pulsing light showing that the pick up coil in the dist is working to send a signal to the ign module to generate a spark through the coil.
3. remove one of the spark plug wires and if you have an old spark plug place the plug wire on it and lay the plug shell on a grounded portion of the engine. Then crank the engine and watch the plug for spark. You will either have spark or not.
Depending on the result you get will determine your next step.
If you didn't have the expected results in the first 2 steps let us know . OK ?
Old Aug 13, 2011 | 04:52 PM
rick32's Avatar
OK so I couldn't find my test light but I found a multimeter. I have 12 volts with ign on but no change in value from the other side of connector when cranked.does this tell us anything? Thanks in advance.
Old Aug 20, 2011 | 11:31 AM
rick32's Avatar
I don't think it's a spark issue since it starts with Carb cleaner sprayed in the throttle body .any experts out there?
Old Aug 20, 2011 | 09:49 PM
Bullitt94's Avatar
When you turn the key to the "on" position, do you hear the fuel pump priming? Did you check fuses for the fuel pump?
Old Aug 21, 2011 | 10:58 AM
rick32's Avatar
I can hear the pump. A long stream. Of fuel releases when the key is cranked and the valve on the engine is pressed (looks like the tire inflator valve)
