93 lighting fire to coil / no start
How have you diag'ed the ignition system? One side of the coil will have fire from the igniiton switch, the other side will close ground to saturate the coil and fire it. You should have a constant light on one side and a blinking light on the other side with the engine turning over. To do a proper test and remove the ECM from the circuit, you should disconnect the spout wire at the distributor.
FloridaE150
Mar 15, 2013 02:44 PM
focuslover
Dec 6, 2007 01:26 PM
