94 F150 4.9 sudden terrible idle
Old Aug 18, 2017 | 02:22 PM
Horseface84's Avatar
Default 94 F150 4.9 sudden terrible idle
Ford friends, I started my 94 F150 Tuesday, and I thought the motor was going to shake right out of the truck. The Idle was, well unbelievable, and I have never heard my K&N filter drawing that much air. So, I looked at the major 3.Replaced MAP sensor, IAC valve, and just now TPS. A little better but still hammered ****. Son bringing home fuel filter. Any Ideas????
TY
Rick
Old Aug 18, 2017 | 03:32 PM
Sometimes my lite comes on upstairs, most of the time its pretty dark up there !
You didn't say how it runs at higher RPM.
If it smooths out at a higher RPM , I would suspect a vacuum leak.
If it stumbles much the same , water in the fuel?
If it was in a very damp wet location , check under the dist cap for moisture.
There is always the possibility it has jumped a tooth with timing.
Old Aug 19, 2017 | 07:39 AM
Default Hanky,
Hanky, TY for response. High RPM motor smoothes out. Changing fuel filter aftet verk. Will check vac system.
inewhall
Jun 25, 2017 05:01 PM
kylet11
Mar 11, 2013 05:59 PM
83grandmarquis
Jan 17, 2012 08:21 PM
99NascarF150
Sep 7, 2008 11:33 PM
tomgold
Feb 17, 2008 05:20 AM
