94 f150 5.0 stumble around 1500 RPM
Old Sep 30, 2012 | 09:56 AM
warrenp099's Avatar
Default 94 f150 5.0 stumble around 1500 RPM
New guy here with a problem. Any help would be appreciated. My 94 F150 has a sort of stumble at around 1500 RPM. I had a reman engine installed, the old one used oil and just wasn't performing good. The stumble was there before the engine change and I actually thought it was a tire. I was wrong. I have no codes or CEL. I have replaced almost everything except the MAF and O2 sensor. It has a new PCM, Distributor, plugs and wires, EGR and regulator and EGR sensor, TP sensor, injectors, and coolant sensor. I don't have a vacuum leak. I can duplicate the problem at idle by bringing up the revs to about 1500 and the engine shakes. I have the EGR blocked off at the moment but it gets alot worse if I hook up the EGR valve. Is this a wiring issue? I really want to get this fixed, this is my main daily driver. I want to restore this truck but don't want to go any further until this problem is fixed. Help!
Old Sep 30, 2012 | 01:39 PM
bandit1948's Avatar
you don,t suppose the timing is off or a valve sticking ? check the timing with a timing light ! also hook up a vacuum tester to the engine to see if there are any vacuum leaks, it also will tell you if there is a valve sticking !
Old Sep 30, 2012 | 02:39 PM
warrenp099's Avatar
Thanks for the reply. There are no vacuum leaks and it was doing this before the engine swap so I'm thinking it's not a sticking valve. I set the timing so I believe it is correct. I'm was just wondering if it could be a wiring problem or something like that. I was hoping somebody has seen this same thing before.
Old Sep 30, 2012 | 02:56 PM
You didn't mention it, but have you done anything with the fuel system like check fuel pressure and/or change the fuel filter?
It would probably be a good idea to check the fuel pressure especially considering all you had done and it should perform better than it is.
Old Sep 30, 2012 | 04:56 PM
warrenp099's Avatar
I changed the fuel filter but have not checked the fuel pressure. What should it be? I will try and check it this week.
Old Sep 30, 2012 | 05:15 PM
85_ranger's Avatar
i belive fuel rail pressure should be around if not right at 40 psi
Old Sep 30, 2012 | 06:27 PM
It is important to observe the fuel pressure at the time the problem is occurring.
Old Sep 30, 2012 | 06:28 PM
warrenp099's Avatar
I'll check it this week. I'll have to get a gauge. Thanks for the replies, this is something I've been dealing with for about 6 months and hope to find a solution soon. I'll let ya'll know what I find.
Old Oct 6, 2012 | 09:54 PM
Flapless Jack's Avatar
bumped
Old Oct 7, 2012 | 08:43 PM
warrenp099's Avatar
Thanks for the bump. I still haven't had a chance to check the fuel pressure. I did replace the MAF and O2 sensor but that didn't help. The other day when I was driving home it started running really rich and shaking to the point that it felt more like a tire coming off than an engine shake. I turned of the OD and got the revs up and made it home. Right before I got home it actually cleared back up. the CEL came on and I had a 157 and 173 code in KOEO. So I replaced the MAF and O2 sensor. I still need to check the fule pressure but I will be out of town this week so it will have to wait till I get back.
