97 Ford F-150 not starting
Old Feb 1, 2023 | 03:14 PM
zapnesto's Avatar
Default 97 Ford F-150 not starting
Ugh I’m so frustrated already and need help on figuring this out. My truck is able to crank doesn’t sound bad it’s tuned over once but then off in seconds. The battery is good I have a new alternator checked fuses. This is my only way of getting to school so please help!!!
Old Feb 1, 2023 | 03:40 PM
aquanaut20's Avatar
DO you have an immobilizer light on dash, red key or lock ?
Old Feb 1, 2023 | 06:18 PM
zapnesto's Avatar
No I don’t have any that light on. I have a all metal key for my truck also.
Old Feb 1, 2023 | 09:37 PM
aquanaut20's Avatar
Now is the time for diagnostics, do you see a spark at the plug/wire ?
Will it fire up on donor fuel ?
Old Feb 2, 2023 | 01:30 PM
aquanaut20's Avatar
You are guessing without any tests, what is the fuel pressure (Gauge), and will it start on donor fuel ?
Without your assistance there is nothing more I can do..
Old Feb 2, 2023 | 01:56 PM
If you want to try this,
After trying once to start the engine, remove one or two spark plugs and tell us if you found them wet or dry.
Depending on what you find will determine where we go next, OK?
alair
Dec 1, 2008 05:57 PM
crash!!
Jun 23, 2008 09:37 PM
stang
Jan 28, 2008 02:07 PM
hokeknight
Jun 22, 2006 01:51 AM
hicracer
Jan 31, 2005 10:16 PM
