98 F150 Brake Problem
Old Jun 9, 2012 | 03:14 PM
a1d2's Avatar
Default 98 F150 Brake Problem
The right front (passenger) brake caliper locked up on my 98 F150. I let the truck set too long. I replaced the caliper and rotor on the right front and did a front brake job.Bled out both front calipers.Started on the right first.I finished the job and took it around the block and the right front brake locked up again. I could smell it and noticed it was smoking like it did the firat time. I noticed that the right wheel seemed to be very tight when i tightened the wheel lugs but thought it was just from being new. I've done brakes before and never ran into this problem. Is there something i'm missing? I would appreciate any help i can get. Thanks
Old Jun 9, 2012 | 04:47 PM
There are a couple things that come to mind.
First did you replace the caliper only or did you replace the caliper with new glide pins?
If you only replaced the caliper and did not insure the glide pins were clean , free and lubricated that could be one possibility.
Another could be , the brake hose to that caliper may have a restriction inside and not allow the pressure to release the caliper.
Also, check the entire brake line for that caliper, for a crimp that would cause a restriction .
Old Jun 9, 2012 | 06:16 PM
a1d2's Avatar
Thanks hanky,i replaced all the hardware that came with the caliper including the glide pins.Used a light coating of grease on them.I kind of wondered if it might be in the brake hose.I'll check it next.Thanks again
Old Jun 9, 2012 | 07:30 PM
FYI , The lubricant that is used to lube the glide pins should not react with the rubber boots over the pins. Some synthetic greases will do just fine.
Old Jun 10, 2012 | 04:27 PM
a1d2's Avatar
I replaced the brake hose and it solved the problem. Thanks again for the heads up Hanky. Never had a breake hose go bad before.
Old Jun 10, 2012 | 07:49 PM
Glad to have been of some help. Thanks for getting back to us !
BornFree0708
Oct 9, 2014 06:56 PM
vibher
Apr 29, 2013 04:42 PM
F150beater
Jul 2, 2012 02:00 PM
rxbahamut
Dec 18, 2010 09:41 AM
hotmnguy18
Dec 7, 2006 01:09 AM
