99 4.6l v8 f150 tachometer
Old Oct 31, 2006 | 03:14 PM
stephenjohnson86's Avatar
Default 99 4.6l v8 f150 tachometer
am having trouble with my truck when i first bought my truck it didnt have a tachometer in the dash i thought ok i'll go buy one the only problem is i dont know where to hook it up to i've tried everything that i can think of and it just dosent want to work is there anyone out there that can help me or knows somewhere where i can look for one.
Old Nov 2, 2006 | 11:30 PM
Mulletman's Avatar
Default RE: 99 4.6l v8 f150 tachometer
Usually a tach has instructions. The red wire is for backlight, the black is ground, and the green one hooks to one of the wires on your coil-pack but not sure which coilpack wire it is.
Old Nov 3, 2006 | 01:53 AM
If your adding an aftermarket standard tach to a distributorless ignition system, a tach adapter is needed.. There are vendors like Autometer, MSD and others available.. They generally run about 70.00 but can be listed/found on ebay ect. sometimes for a bit of a discount...
Here are a few links... Autometer for the adapter, and the PDF install instructions for coil pack, COP ect. just for general information...
http://www.autometer.com/cat_accesso...il.aspx?vid=99
http://www.autometer.com/download_instruction/561.pdf#search='autometer%209117'
Old Nov 4, 2006 | 12:25 AM
Mulletman's Avatar
^ He's right! If that is a COP setup, then you will need the tach adapter. Forgot about that.
balzican
Dec 2, 2006 10:47 PM
stephenjohnson86
Oct 31, 2006 03:13 PM
tritheory
Oct 4, 2006 08:38 AM
F250LOVER
May 23, 2006 12:32 PM
