99 F-150 Clutch Removal
Old Apr 26, 2007 | 01:31 AM
speedfever22's Avatar
Default 99 F-150 Clutch Removal
Anyone that has or is going too have this job on there hands, The pilot bearing that is located in the crank sometimes freezes up from the heat off a worn clutch. You can bust the roller bearings out and pack it full of grease and use a tight fit socket with grease too sometimes drive out the old bearing. Autozone and Advance have a tool made for pulling this pilot bearing, However the tool they will loan you is very cheap medal and will break as soon as you start too put the presure too it. I hope this gives someone a heads up on the job.
Old Apr 28, 2007 | 03:41 AM
91explorer12323's Avatar
Default RE: 99 F-150 Clutch Removal
Thanks for the heads up!! I dont think I have ever got a loaner tool from AutoZone that wasnt junk from the get go or junk due to the obvious over use and or abuse by others. Nice of you to let us all know ahead of time about that paticuler type tool from there.
makuloco2000
Jul 22, 2014 08:33 PM
jmelees
May 17, 2012 02:38 PM
cyberrkatz
Jul 7, 2010 09:46 PM
skid2964
Sep 27, 2009 02:29 PM
Spladge
Mar 14, 2009 01:46 PM
