99 f150 faulty door locks
Old Mar 24, 2009 | 11:23 PM
onebgbdwolf's Avatar
Default 99 f150 faulty door locks
driver side door lock doesnt wanna go up when button is pressed. sometimes down works. passenger switch seems fine and usually works passenger door. have had rare occasions it doesnt wanna work.
does this sound like a faulty switch or the accuator possibly causing the problem?
Old Mar 29, 2009 | 07:10 PM
b rabbit's Avatar
replace the actuator ford has a problem with these going out the new ones have been redesigned and work much better takes about a 1/2 hour to replace. they used a plastic gear with a metal lever and this causes the gears to been stripped right off . If you need advice on how to do it e-mail me and i 'll tell you the instructions .
lcummings
Sep 20, 2010 09:31 AM
lcummings
Sep 19, 2010 09:59 PM
Zapman
Feb 16, 2009 06:29 PM
Mike11C
May 27, 2007 02:14 PM
Aussie Explorer 98
Dec 15, 2005 06:37 PM
