abs light
Old Dec 30, 2006 | 07:00 PM
huntertdm's Avatar
Default abs light
the abs light on my 2000 F150 is always on, i took my truck to a local Ford dealer, they told me the cause was my speed sensor? anyone ever heard of this? i also have a broken emergency brake cable, the told me to replace the cable they also need to replace my rotors, anyone ever heard of this?
thanks
T
Old Dec 30, 2006 | 07:49 PM
Default RE: abs light
The speed sensors 'do' fail fairly often and is a common repair. Not only to your specific MY/application..The cable is replaceable 'without' a rotor replacement, unless they saw a reason during an inspection? The rotor/s utilize a 'drum in hat' type ebrake, and if the ebrake had dragged ect. a rotor/replacement may be needed.. Or if the rotors were beyond/below minimum service spec limits..
Here's a pic of the disc brake/ebrake and the hat/drum system..
And the rear diff. speed sensor should you want to do the replacement yourself.. One bolt, plug'n play...
[IMG]local://upfiles/6756/FB2BE6F3809E4684BE770776D2CD09C0.gif[/IMG]
[IMG]local://upfiles/6756/99EF6124A1F94EF0B1CEF8DB9EA83C5C.gif[/IMG]
Bob Lobblaw
Apr 9, 2009 09:00 AM
Justin7666
Apr 11, 2008 02:04 PM
Hutch64
May 31, 2007 09:21 PM
