Bleeding rear calipers
Old Dec 27, 2022 | 07:20 PM
curt1966's Avatar
Default Bleeding rear calipers
I have a 2001 F-150. I replaced all 4 brake calipers and was able to gravity bleed the fronts no problem. However I can not get any fluid to rear calipers even with a helper pumping the pedal while I open the bleeder screw.
Old Dec 29, 2022 | 05:44 PM
Some vehicles had a height limiting valve that based on the load the vehicle carried , controlled the application of hydraulic pressure to the rear brakes to prevent rear wheel lock up. Not sure if that is on your vehicle.
Old Jan 1, 2023 | 02:43 PM
curt1966's Avatar
Thank you. I will check into that.
markf1971
Apr 10, 2021 02:41 PM
choncy77
Apr 27, 2018 02:38 PM
brokemercntx
Jul 14, 2012 08:54 PM
samford1
Oct 10, 2009 11:00 AM
ras3355
Nov 10, 2006 08:22 PM
