Blown Fuse
Old Jan 18, 2008 | 04:33 PM
wow's Avatar
wow
Default Blown Fuse
My automatic headlight fuse blows every time the headlights turn off. I replaced the main headlight switch, but it did not help. Could the light sensor switch in the dash be bad? Is there a relay somewhere that may cause this? Any ideas??? HELP!!!!
It's a 2002 f150 super crew, 5.4 engine.
Old Jan 18, 2008 | 05:31 PM
btexpress's Avatar
Default RE: Blown Fuse
No ideas, since you haven't divulged what year or model you are asking about.
Old Jan 19, 2008 | 07:54 AM
wow's Avatar
wow
Sorry, My truck is a 2001 f150 super crew, 5.4 engine. THANKS!!
Old Jan 19, 2008 | 03:22 PM
b rabbit's Avatar
if you could tell me what fuse exactly blows i could tell you what is wrong !the fuse number should be on the other side of the cover .
Old Jan 21, 2008 | 03:13 PM
wow's Avatar
wow
Fuse # 29 is blown.
Old Jan 22, 2008 | 01:17 AM
b rabbit's Avatar
that fuse is for your autolight sensor. i would replace it if i were you it's probaly shorted internally .are you sure it's 29 the 5 amp fuse? if it's that fuse the sensor or the circut is shoted to ground.if you have a multimeter check for continuity at ckt 474, orange with a light green tracer it's one wire located in under the hood on the driver front side. put one lead at fuse 29 (make sure it's a good fuse, or just pull it out and probe the connecter on the side that doesnt have batt. voltage.) put the other lead at the sensor connector and check for continuity if you have it. replace the sensor if you don't , follow the wire untill you find the short to ground, and just solderand shrink wrap it.That sensor is the only load on that circut ,so if it shorts out it will blow the fuse when you turn you headlights off.because you switch the relay and power goes to the sensor and that sensor only allows currunt to flow to the headlamps if it doesn't see light. the sensor it self is on the bumber in front of the drivers side headlamp first look at it and see if it's damaged most likly a o.e.m. part so you'll have to go to Ford for a new one.
p.s the spec for the sensor is
0.285 and 0.315 ohms.
spmaster
Feb 4, 2007 05:20 PM
1997 blue expedition
Dec 12, 2006 01:02 PM
shellie
Jan 14, 2006 12:45 PM
shellie
Jan 14, 2006 09:28 AM
ChaostheOmen
May 9, 2005 04:13 PM
