Crank no start
Old Mar 13, 2022 | 07:14 PM
NMVarmit's Avatar
Default Crank no start
​1996 F150, 5.0L 5-spd 4x4
Crank no start, ambient temp has no effect
Plug in the diagnostic scanner clear DTC's it starts every time, starts for the rest of the day, runs smooth and strong, the next morning crank no start, repeat
Parts replaced-battery, solenoid, starter, 3-O2 sensors, dist. cap rotor plugs wires, crank shaft position sensor, coolant temp sensor, a/c components, coolant temp sending unit, fuel pressure regulator, ecm (yes it was programmed to the vin), fuel filter, egr solenoid.
Things checked-ground strap from rad support to frame, ground from frame to cab, ground from intake bracket to firewall, ground from battery to inside fender well, all fuses, fuel pressure, there is fire coming from top wire of ignition control module for pip in distributor, disconnect the battery over night has no effect.
F150junker
Aug 5, 2020 04:08 PM
fastonraceday
Aug 5, 2020 01:06 PM
John Tillman
Sep 15, 2017 05:16 AM
Warren Hart
Jun 10, 2013 03:23 PM
jkmo
Jan 16, 2011 06:21 AM
