door ajar beeps after keys are removed
Old Dec 22, 2011 | 08:20 AM
taztank's Avatar
Default door ajar beeps after keys are removed
Need help. For past year when you remove the keys from our Ford F150(1997) the door ajar sound continues sometimes if you turn steering wheel it will stop. Also the door locks have recently started to go nuts and lock and unlock randomly. Truck can be in Park or you can be driving. Any suggestions?
Old Dec 22, 2011 | 12:20 PM
Have seen this problem and corrected it by replacing the ignition key tumbler unit.
Not sure if this would correct the problem with your vehicle.
Old Dec 22, 2011 | 12:31 PM
Sounds like the 'key in ignition' sense is creating the chime tone, not door ajar. With the key 'out' of the ignition and the chime tone active, try and 'slightly' rotate or rock the ignition lockset back'n forth. If the tone stops, the key sense is the problem. Really common for the 'plastic' mounting tang to break (just slides onto the lockset bore) and the small brass grounding prong to then short causing the failure and tone. The ignition lockset has to be removed and the column covers pulled to check. If it is broken, Ford doesn't offer a repair pigtail (its a single wire circuit) and the air bag clockspring has to be replaced. Or,, if your really not too worried about the key sense, you can just tape the connector plastic, or cut off the end, and move it away and down from the ingition into the space below, replace the lockset and covers and go without. Does the 'wing' portion of the lockset seem loose or rotate slightly or excessive with the key removed? If so, it can cause the sense issue as well..
mike 96 ws6
Sep 25, 2012 08:25 AM
Sangasu
Sep 8, 2009 09:01 AM
Zapman
Feb 16, 2009 06:29 PM
kwillis
Oct 21, 2008 06:06 PM
Mike11C
May 27, 2007 02:14 PM
