E4OD 4th gear start issues
Old Oct 20, 2017 | 11:01 AM
  #11
Originally Posted by Vmsons02
Okay,finally got to run this diagnostic. Volt meter + on red Pin and - on Orange and yellow key off 0 with key on and shifter in D voltage was reading same as Red Pin in key off. (Battery voltage)
Read that a few times,,
So your seeing no voltage with key ON~D on your meter, and Battery voltage Key OFF?
Old Oct 23, 2017 | 08:31 PM
  #12
Vmsons02's Avatar
Seeing voltage when in key ON~D and no voltage with Key~OFF.
Old Oct 24, 2017 | 05:29 PM
  #13
Vmsons02's Avatar
[QUOTE=Vmsons02;104718]Seeing voltage when in key ON~D and no voltage with Key~OFF.[/QUOTE
Again thank you for all your help!
Old Oct 25, 2017 | 07:42 PM
  #14
Vmsons02's Avatar
[QUOTE=Vmsons02;104730]
where you go Hayapower?
Old Oct 26, 2017 | 08:48 AM
  #15
When you replace the harness/s did you replace with repair pigtails?
Testing the pins for power distribution and PCM supplied grounding to manage or operate the solenoids should prove out electrical control. Since you replaced the solenoid pack doubt they'd be the issues, more so since no codes are reported. Could OHM test the solenoids to make sure their values are spec, but again if off, codes generally would be generated.
How many miles on your E4? The symptoms are the exact same prior to the pack and the MLPS replacements?
Old Oct 26, 2017 | 09:33 AM
  #16
Vmsons02's Avatar
Yes, replaced with pigtails and have gone back to double check making sure wires were connected correctly. 163,000 on E4 assuming its original. Same symptom since all replacements. Only code that keeps coming up on scanner is 654 “not in Park” but truck starts in P. Could replace again “MLPS” since it’s cheaper than PCM?
Old Oct 26, 2017 | 10:45 AM
  #17
MLPS was indexed on its scribed marks?
One of the reasons I asked about prior isssues or 'after' parts replacement is,, during the MLPS replacement the manual lever needs to be held from rotation. If not and allowed to rotate over during the replacement it can put stress on the internal detent spring/tab and bend it causing the manual spool valve to be off position causing a cross bleed for line pressure/applications. Doesn't happen to often, but can..
If it was bent, generally will show up when indexing the sensor, or having difficulty with enough slot range adjustment to the index. If you still have your old sensor, you could ohm test to cross check new to old values before another new. Same with the solenoid pack.
The MLPS is a drop down series of resistors for position reporting. If the PCM doesn't see the correct value usually 634 is stored, if missing, 654 is generated. You could also ohm test the MLPS connector to the PCM connector in case there's a circuit open, short, high resistance etc..
Sounds like it's electrical in nature, more so since the manual shifts are correct.
If you know anyone, or have a scan tool capable of PIDs you can see the MLPS ranges on screen during selections as matched to the sensor and the shift lever positions...
Old Nov 10, 2017 | 07:47 PM
  #18
Vmsons02's Avatar
sorry for delay new work schedule. So,i have double checked MLPS position and is correct, pulled harness and checked all wires for continuity and correct pin location, also correct, and installed a new ECU with no change of symptoms. Hope these repairs narrow fix since she is driving me crazy!
makuloco2000
Dec 31, 2013 09:43 PM
sf49erfn
Jan 26, 2011 05:03 PM
cdies
Jan 6, 2010 01:57 PM
rustbucket89
Nov 8, 2009 09:05 PM
llewjay
Dec 2, 2008 04:32 PM
