electrical problem
1997 F150 2wd 4.2 with auto trans (its a basic truck, no electric windows eventhough it has a GEM)
Can anyone help with any of these?
I have a few electrical problems that I hope are related:
1. There is a wire that is loose next to the ignition switch that looks like it snaps onto the outside of the switch (between switch and the steering colomn plastic cover) it has a brass contact that looks like it goes into the switch. What is this wire??
2. There is an alarm under the glovebox that I have never heard before (in any car) sounding off once and a while. What can it be telling me??
3. The wipers do not come on every now and then. Wires and multifunction switch seem okay.
4. I am on my second alternator. The first wined a couple of weeks like it had a bad bearing before it stopped charging.
5. The alternator now is only putting out about 1.25v about the battery instead of the 1.75v when I put it in.
6. How will an alternator go bad if it is charging a battery that does not have a full charge? Does that mean you can not jump start a car without risking an alternator?
7. The heater fan stays on without the key
8. Someone in the past broke the the lock for the steering wheel. I assume by turning the wheel when it was locked.
Thank you
Thank you
1992, 2008, alternator, edge, electrical, escape, excursion, expedition, f150, fan, ford, freestar, issues, problems, stays
