Engine Fan
Old Mar 25, 2021 | 12:54 PM
1Dozerdawg!'s Avatar
Default Engine Fan
Have a 2018 F150 Lariat with the 3.5 Eco boost. The last couple of months the fan on the motor seems to always be running at high speed. When you slow down at a stop sign you can hear inside the cab. My temp gauges doesn't indicate it hot. Any thoughts of what is going on?
Old Mar 28, 2021 | 01:57 PM
scott.butler4's Avatar
You should check if only one fan is running.
You should check for voltage at the connector for whatever fan is not running.
I would assume one is not running and you should check the wiring harness for damage to that particular fan.
Old Mar 29, 2021 | 07:24 AM
Actually both fans are running. When this happens the water temp of radiator get to around 240 degrees, but never above!
Old Mar 31, 2021 | 05:00 AM
raski's Avatar
240 is on the hot side and the fans should be running at the temp .The cooling system should be able to maintain an operating temperature at no higher than 220. Anything above is excessive in my opinion. I would use an IR thermometer and also connect a scan tool showing live data to actually see what temperature your engine is running at.
Old Apr 13, 2021 | 08:47 AM
The Ford dealership said it was running hot because the radiator was leaking, which it was. However we replaced the radiator and the temp gauge still gets up to 235+ most of the time. What would be causing the engine to run so hot all the time?
pilleway
Feb 28, 2011 10:48 PM
dshardaway
Jul 13, 2010 08:33 PM
americanmade929
Apr 20, 2008 11:00 AM
daveranger
Oct 31, 2006 04:54 AM
schlepie
Jun 6, 2005 11:50 AM
