Engine Misfire # 8
Old Jan 25, 2011 | 10:17 AM
marvw's Avatar
Default Engine Misfire # 8
Have a 1997 F-150 4.6l 4x4, runs rough misfire # 8 has 120 lbs compression, plug is black when i take it out, swaped plug with another hole same problem, took plug out and grounded it out and it has spark but could it be to weak?
Old Jan 25, 2011 | 01:01 PM
One of the reasons for the plug being black is excess fuel getting into that cylinder. That can be caused by a leaking injector for example. Also if the spark available to that cylinder is strong enough to look good with no compression it just might not be strong enough to fire the plug when under compression. Switch the plug wire with another and see if that changes anything.
mardyel
Sep 23, 2025 05:41 PM
disbanded
May 12, 2008 08:03 PM
robbyb55
Jun 24, 2007 11:31 AM
ddybrown
Mar 31, 2007 02:40 AM
sunderco
Dec 31, 2005 09:07 PM
