engine noise when cold
Old Feb 20, 2008 | 12:09 PM
bmarnall's Avatar
Default engine noise when cold
my 2001 5.4 makes a loud tapping noise when cold. Sounds like a lifter that isnt pumping up. Noise will come and go until engine is completely warmed up and then you wont here it anymore. Oil level and pressure is good. Since this is an overhead cam engine and doesnt have lifters, I'm not sure what to look for. I see there is a lash adjuster, are these hydraulic and could this be the problem. If so is this a difficult replacement? 128,000 miles on engine.
Old Feb 20, 2008 | 07:41 PM
gogrimmy's Avatar
Default RE: engine noise when cold
First a Question, do you use Fram oil filters? I read somewhere ( I think it was on the old ford tractor forum ) this one guy did a comparion of oil filters, cut them up to see how they are made and Fram quality has fallen off. I had a cold start tick on my 97 F150 112,000 miles, Changed to a Wix filter and haven't had that problem since. ( I will post the link if I find it )
Old Feb 21, 2008 | 08:09 AM
bmarnall's Avatar
Always take it to the lube shop, not sure whose filters they use. Oil is changed at proper intervals.
rpalm
Mar 4, 2011 04:20 PM
wschmidt
Jan 23, 2010 03:22 PM
jimmijones
Jan 4, 2010 06:01 AM
wpgbronco
Nov 27, 2005 02:21 PM
pamolnar76
Sep 15, 2005 06:52 PM
