ford 150 no fire to plugs
Old Mar 1, 2014 | 11:56 AM
  #11
grindman's Avatar
another thing that people tend to forget is the rotation of the dist. if that is in the wrong direction it would cause the same problems it should be counter clock wise. and the way the pistons are numbered could have something to do with it as well
Old Mar 2, 2014 | 07:39 PM
  #12
tom hartzell's Avatar
have checked all that going to try injecters out of anouther 302 i got i think thay were bad an not injecting fuel, cause i pulled the intake an some of the holes were pluged up with crap this motor is really dirty inside, so it,s set for a long time
Old Mar 4, 2014 | 03:15 PM
  #13
grindman's Avatar
you might try this simple test to see if the gas is good enough to run the engine, take a little gas out of the tank or lines and pour it into a glass jar or on the ground and strike a match to see if the gas will burn. and you should almost always buy new injectors if you're gonna replace them it doesn't take very long for injectors to clog up and not work
carsnewstoday
Apr 28, 2014 07:41 PM
screechv10
Apr 23, 2013 09:05 AM
myers_8
Oct 18, 2011 03:10 PM
redrider24
Aug 20, 2011 08:46 AM
moondogee
Apr 26, 2005 07:16 PM
