going in circles
Old Apr 13, 2024 | 10:24 PM
jgandreas63's Avatar
Post going in circles
this is a 2014 ford f150 xlt 5.0 l 4x2 . trac advance light on only. im not sure but i think it might be something to do with abs control module unit. prior to my cruise control stop working. i replaced purge valve , left front abs and hub asembly, and brake switch. nothing resolved?
Old Apr 14, 2024 | 03:13 PM
Sometimes you can perform what is called a forced reset.
Just remove the negative battery cable from the battery and go have a cup or two of coffee, (or what ever you like lol) and then reinstall the cable terminal back on the battery post .
.Let us know if this made the light go out. It will not correct the initial problem, but we can go from there.
4everblue
Jun 30, 2020 07:45 PM
LAUDERMAN
May 27, 2014 10:44 PM
Use Common Sense
Aug 14, 2010 10:07 PM
M W
Mar 12, 2009 05:56 PM
chuda440
Nov 14, 2007 10:57 PM
