Hello Ford Forum, Help Needed
Old Oct 28, 2020 | 11:05 PM
grady fx4's Avatar
Default Hello Ford Forum, Help Needed
High Idle @1800 RPM, new IAC valve, new EGR Solenoid , no vacuum leaks, no codes yet, #puzzled...
Old Oct 29, 2020 | 01:39 AM
raski's Avatar
Did you also clean the throttle body of accumulated carbon especially the bore which the AIC pintle resides in? What happens if you unplug the AIC solenoid? Is the throttle body binding in any way where the throttle shaft is not returning to a fully closed position? Did you or anyone mess with the "forbidden" screw on the throttle lever called the hard stop screw? You didn't mention much details about your truck but I would still be looking for vacuum leaks associated with the PCV and the brake booster plumbing.
Old Oct 29, 2020 | 09:46 AM
grady fx4's Avatar
Thanks Raski,I have a 03 F150 5.4l FX4,i did not touch the forbidden screw but when I unplug Iac it shuts off, now i will tell you that just changed the intake and only used factory parts (intake & gaskets) proper torque sequence and pounds. I only checked PCV for leaks, just puzzled now , I'm missing something, any suggestions would be greatly appreciated, Thank Gradyfx4
Old Oct 29, 2020 | 02:44 PM
raski's Avatar
Connect a scan tool. Recheck for any stored codes. Then check your fuel trims.The long term fuel trim(s) is the most important. If you have a vacuum leak, the mixture will be lean because of it. The computer will attempt to add more fuel resulting in a positive reading. Anything above 5 is concerning.
Old Oct 29, 2020 | 03:58 PM
grady fx4's Avatar
Thanks again Raski, I’ll check the fuel trims today, also what do you mean concearning
Old Oct 31, 2020 | 05:18 AM
raski's Avatar
When you get over +/- 5 there may an a problem somewhere requiring troubleshooting. Get over a +/- 7 consistanty, a code will be stored.
grady fx4
Dec 7, 2020 03:59 PM
Welderguy
Mar 14, 2016 07:39 PM
RonaldD
Feb 28, 2011 06:39 PM
JMD87
Nov 8, 2008 10:14 AM
Loum12
Mar 24, 2005 03:28 PM
